lamian,
Check the volume level in the camera settings. Log in to your Aro account and navigate to Settings > My Devices > select your Arlo Pro > Audio Settings > Adjust the Speaker volume slider.
No point in having it as a 2 way device. It's simply not strong enough.
lamian,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Logic would dictate that reversing the roles of both mics would lower the output to the Arlo Pro cam. The rear mic on the iPhone is used to detect background noise and erase it from the main mic. If you reverse this, the main mic would pick up louder sound and cancel out the rear mic almost completely.
This is most likely the cause for the whisper quiet output from the Arlo Pro can. Netgear needs to correct their application!
All my devices up to date, phone app up to date, reconfigured entire system and synced devices again, still Same garbled inaudible speaker. Volume in app to max.
This is ridiculous really.
M0381U5,
If you're sure all settings are correct, please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
I for one did everything as instructed. Even contacted support who did everything to blame it on anything besides the camera. In the end they sent a replacement. Slight improvement but not enough for someone outside to be able to here you without putting their ear up to the speaker. To all interested in the PRO if you want it for the mic and speaker then go elsewhere. If you wnat it for the video survallance then its perfect but you can buy cheaper Arlo and be happy. The pro with its current speaker and App arent worth the extra money you must lay out. If you are only going to use a PC then it may work for you. Volume is a bit louder and thats how Support test it when you are on with them. They dont use the app on a phone. Yes they advertise it to wok great with the APP. Misleading if you want to talk with the person at the at the door. From what I can see on the forums its been going on for quite a while and nothing seems to be improving.
Jess
