Arlo pro batteries will not charge
Please advise before I throw this out my window
What have you tried? There's also the Contact Support link at the bottom here to open a case for possible hardware failure.
Here are two possibly helpful links:
https://community.netgear.com/t5/Arlo-Pro/Arlo-Pro-Won-t-Recharge/td-p/1166893
If that doesn't work, contact Support.
Brian
How many cameras have you got? If you use a combination of different cameras and batteries, you should be able to ascertain whether the problem is with the camera, the battery, or the charger. IIRC, there was a thread where someone's Arlo charging adapter was faulty and so after they contacted support, they were sent a replacement adapter that fixed the issue. Alternatively, you could buy a spare charger that comes with a cable and either a spare battery or a charging station. It's a bit of a silly setup because if you buy the spare battery with charger and cable, you have no way to charge the spare battery because only cameras and the charging station can charge the battery. If you buy the charging station, you'll get the charger and cable but won't have a spare battery to put in the charging station. Don't ask me why they did this
I'm still having issues with my camera not charging as soon as I plug it in it turns off but if I plug it in without the battery it stays on in the power cord mode
Yesterday I was able to get the battery charging indicator light but this morning the battery did not charge at all and I cannot get the battery charging indicator to come back on
I do notice however when the battery is inside the camera while it charges if it doesn't turn the camera off the blue light will blink once and then about 5 times after but still no charge
It's sounding more and more like a faulty battery. Have you contacted support?
Scroll down the page here and in the green bar is a button that says Contact Support. That should take you to a page where you have a few options to contact them and get your issue sorted
