Arlo pro alarm
How can I activate the alarm mode when I have 2 cameras outside an 2 inside and I would like to activate only the inside ones?
You will need to creat a cutom MODE where the inside cams have the alarm off OR you can just arm the outside cams
( split them to inside/outside )
read;
