Arlo pro Base Station (sim/vlan connections)
I have set-up my Arlo with vlan (internet) conncetion. I am planning to put it on UPS and install sim card. Could you please let me know what happens when I connect sim card and vlan to Arlo at the same time? Which data will be used by default - cellular or vlan internet?
My expectation is that it uses the vlan data by default and if power is lost or vlan connection brokes, then cellular data is being used instead. Is this only how I imagine?
Thank you!:)
When the base units are connected to your router via ethernet cable... the base will use the default internet access that the router offers
