Arlo netgear wireless reciever
  • 4 Replies
  • 3169 Views
jake77
I want to setup my security cameras without the Internet connection. Can I go this after I have an account and have synced and tested all the devices. I will use a small TV to see the videos and have my own recorder for saving them.
I do not need to use a portable device as that is not secure in todays environment.
No you can not....
It is a cloud based system
No you can not....
jake77
Thanks for your response. I wonder if giving the reciever a wireless connection will work?
jake77
steve_t
Master Master
Technically, you could set it up and then remove the internet connection. This would mean that the only place videos are being saved is the USB HDD or flash drive attached as a backup. You would, however, be required to remove the HDD from the base and plug it into a computer if you wanted to view any recordings. Not very practical. If when you say "I do not need to use a portable device as that is not secure in todays environment" you're referring to the USB HDD, then you're out of luck I'm afraid. If you're that worried about security, why wouldn't you want a wired system?
steve_t
Master Master
jake77
You can use a range extender to provide a remote ethernet port for the base station over wifi
eg
http://www.netgear.com/home/products/networking/wifi-range-extenders/
