Arlo in th hot weather ouside
Does anyone know how arlo pro fares in the hot weather outside?
"The operating temperature is 14° to 122° F (-10° C to 50° C). The camera may not perform optimally in extreme temperatures (tempuratures well below or above the operating temperature) primarily due to the battery constraints." - from another thread
Actually I believe it a bit diff than that Steve...
-4° to 113° F (-20° C to 45° C)
I have tested my Pro in the freezer at -4F and have confirmed at that temp the Pro does shut down ( after a few hours in the freezer ).
States something like... your camera must warm up
It is prob more for battery safety as the li-ion cells should not be charged if below 32F
Funny thing is with Li-ion in the reg Arlo cameras, there is no shut off feature and they have worked to to more than -10f ( and some say even colder )
