Arlo camera us and UK
I’ve brought the Arlo Pro 3 camera system and is due to be delivered tomorrow. as I’m due to go on holiday and want protect on my house, however I’ve since thought as I’m travelling to Las Vegas it may be cheaper to buy a add on Arlo Pro camera from there.
My question is would it be compatible with the UK version? I’m not to technical minded but I can’t see that there would be a issue but I’d like to double check. I’ll looked and there’s a considerable price difference between between US and UK so if I want a add on camera makes sence to but one whilst I’m there.
Any advise and information would be great...
Thank you
Thank you
Yes, no problem at all except you will need a USA to UK adapter for the power supply if you wanted to use the one that comes with the add on camera. You will already have one that works from the kit you are buying in the UK.
See all the other accessories here
https://www.arlo.com/en-us/products/default.aspx?p=prodarlo_pro_systems
while you're busy shopping in the USA.
