Arlo base station sync light not blinking
  • 3880 Views
arlocamera1
When pressing the sync button for two seconds on the Arlo pro base station the light is supposed to start blinking. It doesn't blink, it remains solid green. I have restarted and reset the base station three times. Internet connection is working fine.
I managed to sync two cameras without problems, I only noticed this issue when I couldn't pair the third camera. The third camera shows the blinking amber light after trying to sync.
see if you can move the base a small amount more away from your router....
also try a quick firm push on the base sync button ( don't hold for 2 secs ) and then the camera
arlocamera1
Amazing, that worked. I don't understand how the proximity of the base to the router can have an impact. Thanks
honestly think it was holding the sync button....
biggest issue a while back was directions said to hold for 2 secs ...and it caused non syncing
