Arlo base station says connected but isnt
What LEDs are on on the base and what color are they? Can you live view the cameras on the app?
If you reset the Arlo base station but use the same longin and PW as before the motion video should be there. This is assuming the cames were online and everything was working at the time of theft. If you say they went offline prior to the theft then noting was captured. That's strange that it would go offline but I think that is your point. Any update?
Also, if the cameras were working at the time of the theft, you might have the video on your USB backup drive so check that
Timshannon3780 wrote:
3 lights, they are all green. I can view them live
With those, it should be working properly. Is there a black outlined "running man" figure above each camera in the Devices tab?
To make it simple, if you don't see the video you want in the library, then it was never recorded.
Do you have a usb drive attached? If so, have you checked that?
Sorry, i meant i coukdnt view them live. Says it isnt connected to internet
Not sure about apple, but on android (Galaxy s8), after using the app, I need to use "close all" or next time I use it I get the message that I am not connected to the internet. Really annoying if I get a txt and want to read it while I am using the Arlo app. Don't log out, just close the app.
