Hello,
I wonder if anyone can help- I have a camera installed at a house where we turn off the internet for a few months at a time. However, when I do this and then make the internet active again, the base station cannot be found.
The router and basestation have been left on so I know they are running.
Has anyone else had this issue or can you suggest a solution? I cannot get to the base station to restart it for example.
Thank you.
This seems to be a new scenario presented. If you can't physically access the router and base or have someone else do it for you I'd suggest a WiFi power switch for at least the base (perhaps the router, too) so you can remotely power cycle them.
Does the router respond when Internet is resumed?
Oh what a good idea- thanks for that solution!
If you’re leaving the arlo Base station and battery only cameras active without shutting them down you could also end up attending site to recharge them.
