Arlo app Android
When using Arlo App on my android 7.0, I get problem when I connect the telephone with the Wifi at job. It says Arlo is unavailable. If I turn off the Wifi, I can connect to Arlo.
What is the solution?
Your work internet is probably blocking it. Either ask the network administrator to allow it or just use mobile data
I would like a feature in my Arlo app chosing 4G or Wifi or both.
Running OS 7 on an S7 and no issues...the only time I see a temp glitch is when using on wifi and then put in background, If I move away from wifi to LTE, the prgm sorts of burps for a sec or two till it fiqs out I'm still not on wifi
hallg wrote:I would like a feature in my Arlo app chosing 4G or Wifi or both.
I don't think the app has the ability to have a say as to how your phone connects to the internet. The phone is either on wifi or not. If it's connected to a wifi network, you can't tell an app to use mobile data
