I was having issues getting logged in while Kaspersky was enabled, but not when it was disabled. I contacted Kaspersky and was provided a solution:
Open Kaspersky - Settings (gear icon at bottom)
Select Protection - Wen Anti-Virus
Select Advanced Settings (bottom of screen)
Select URL Advisor - Check URLs - Manage Exclusions
Add https://my.arlo.com/#/cameras
Thanks for info
This issue has caused me a lot of difficulty. I tried doing what JRalph suggests (and nearly every other suggestion) but none of them worked. I am using Google Chrome on a Windows computer and I could only get access to my Arlo account by turning off Kaspersky web antivirus. I discussed the problem with Arlo but they were unable to help so I went to Kaspersky and here is their solution (which works every time), I received this e-mail:
Please do the following in order to add a website to the trusted URLs:
1) In the Kaspersky main window go to "Settings => Protection => Web Anti-Virus => Advanced Settings => Configure trusted web pages
2) Click on "Add", enter the following addresses of the website you wish to add and set the status to "Active"
https://my.arlo.com/hmsweb/client/subscribe
https://myapi.arlo.com/hmsweb/client/subscribe
3) Confirm by clicking on "Add".
So for anyone suffering from this problem I definitely recommend this as the solution.
Thank you for the info. It worked!
Good to know it has been successful.
(Arlo web page is encrypted so the Web Anti Virus Settings will not work - it must be done here.)
In Kaspersky - Kaspersky said next version they will fix the issue
Click on the Settings Icon ..little wheel in lower left corner
Click on Addtional
Click on Network . Network Settings
[SETTINGS]
Checked - Limit Traffic on Metered Connection
Checked - Inject Script into Web Traffic
Monitor selected Ports only
Scan Encrypted connections
On errors with encrypted connections - ask
Scroll down to 'Manage Exclusions'
Add these 3 items to exclusions.
my.arlo.com
myapi.arlo.com
arlo.com
(make sure these 3 entrys are active.)
