Arlo Range Reduced
  • 0 Replies
  • 1660 Views
  • 1 In Conversation
ToniManolov
I can no longer recommend Arlo. I’ve had the exact same setup—same WiFi, same routers, same base station, and cameras—for over three years without any issues. However, about a week ago, after the latest update, everything changed. Now, I can’t place a camera behind a door without it going offline. This was never a problem before. I even moved my base station closer to the front door, but the issue persists. The base station is now just two feet from the door, yet as soon as I close it, any camera behind that door loses connection. I’ve tested this with three different cameras. It feels like they've deliberately reduced the range just so support can push you to upgrade your base station, claiming your setup is outdated.
0 REPLIES 0
