My camera told me my battery was low so I changed it. I still get a time to charge your battery message. I’ve turned it off and on trying to reset it. I turned off the base and back on. The setting says the camera is linked to the base. Am I going to have to pull these cameras down and resink them every time I change the battery?
Yes I did and it worked. I suspect it didn’t make good contact upon the initial attempt. Perhaps the cold weather. Thanks. It came back up.
@JoeCymru wrote:
Did you pull the battery and then reinsert it?
