I can't see any update warnings on the app.
Have I a faulty unit?
Please help!
What happens when you reconnect? What are the battery and WiFi indicators showing? How do you reconnect - resync or reinsert the battery?
To reconnect I've had to remove battery.
battery has been on charge all night with solid blue light indicating full charge.
after re-syncing camera works good for an our or so and then disconnects again.?
Whaat about the WiFi indicator? Full strength? If so, I suspect you either need to open a case with support or swap at the store.
Possible it is battery drop out?
Try and run the camera with just the cable and adapter ( no battery ) and verify that it really is the camera
