Hi
I purchse this unit with the understanding that it was wifi only and did not need to be hard wired into a computer. Help, because step two was hooking it up to my router
Why is hooking the base to the router an issue?
Hooking the base to your router is just a matter of using an empty port in the rear and plugging in the cable to it and then to the base
I know how to hook up the cords, it's not rocket science
We need the camera(s) set up in a barn, that is some distance from the hosue and computer/router.
We have wifi booster from the house to the barn area, but no hardwired internet access.
I purcahse this with the salesmans knowledge that the cameras talk via wifi to the base and te base was plugged into an electrical socket. No mention of needing a router was mentioned (and since I'm not a techy, I didn't ask),
I did purchase another wifi booster. So perhaps the base can be hardwired into that, at the abrn and we will be able to view the cameras on our smart phones and house computer.
I also just strolled on down to the barn with the camera in hand, and the picture wasn't too grainy, daughter could view it on her hone at her house (half way between my house and the barn)
If you had been clear, I would not have stated the answer that way....
The system must be hooked into the internet via an ethernet port.. you can run etherenet cable to a max or 100m ( 300ft ) without problems or use an extender as mentioned...
If you go with an extender, you may ( for your setup ) want to go with an AP/entender that can use a directional antenna to get max signal out in the barn area from you home router.
Good luck
