Arlo Pro wireless Cannot find the base station.
Have the base station connected to local network. Power, Internet, and Camera sync lights all on all green. Try to run setup from desktop compiter on same network. Cannot find the base station.
If the system is closed how are you supposed to run the setup? The instructions say to go to alro.netgear.com and click on the "Discover device icon". It also staTES THAt aslong as the mobile device or computer you are using resides on the same network segment, it will be found. Port 80 and 443 are both open on this network.
Any suggestions??
I'm sorry I misunderstood what you were asking at first. What I meant was you can't log into the base station and get to a configuration page like you can log into a router and get to it's configuration page. I wasn't sure if that's what you were asking about or not.
You should be able to go thru the setup process as long as your base station is plugged into an open network port on your router. I would just run the setup from the app (on your phone, andriod or iphone). I never did it thru the web browser, not familar with that process. But either way, it should see your base. If your base is hooked up right, and no cameras are synced, you should have two green lights on the front of the base. Do you have that?
