Arlo Pro two way communication fails
I purchased a 4 set of Arlo Pro cameras. They work great when I am at home using the same wifi. However, when I am away from home and try to connect to Audio, I have to wait perpetually and sometimes the audio never connects or it just fails miserably (a lot of delay and works sporadically). Can you tell me how I can troubleshoot this? As it stands, the two way audio for this product just isn't reliable when you are out of the wifi area. I hope Netgear has a solution for this. Thanks for your help!
device type, and OS running?
connection on another wifi or 3g/4lte?
I have 4G reception and Verizon when I try to use the two way talk outside of my home wifi. My wifi speed at home is running about 100 MBPS download and 118 MBPS upload
Open a case with support. I have a case open now that was just escalated. Reference my case, #27699727. The more complaints, the more pressure.
