Arlo Pro timestamp is off by 2 hours. How to change it?
It should read How do I change it?
I figured it out!
I have the same problem, but can't seem to fix it. How did you solve this?
Hi @kiiiiim84,
Try changing your time zone to see if that helps. Go to Settings > My Devices > Choose your Base Station > Time Zone. If that still doesn't help, try to reboot your Base Station.
