Arlo Pro solar panel showing not compatible
Good morning. I have several cameras. Software version 2.6.2. I have had a arlo solar panel hooked to one and it’s been charging fine. The cameras recently had an version update. Now the camera that is using the solar panel is saying that the solar panel is not capatible. Asking for advice. Thanks
Might be a fluke. Try restarting the base and maybe reinserting the battery in the camera.
Thanks I will try.
