I'm getting notifications that I have recordings, but my library has nothing. The recordings from the past 10 days are also missing from my library.
It was all working fine an hour ago.
There was a temporary limitation displaying thumbnails and videos the Arlo library. This issue has been resolved. Please contact customer support if you have any questions. Thank you!
i have the same issue
same thing is happening to me.
I am assuming the North Korean's or someone else hacked the system. Mine are also all gone.
Not cool Netgear
If you log on your account on the computer, it is still recording and you can see your previous recordings still. Weird thing though, is that they will periodically all go away and then come back again.
You also cannot search by date. weird..
Yup same here.. Is this happening for Basic plan only? that will be sad if it is..
I cannot locate a number for Arlo. Do they review these threads to see if any issues?
Hello All,
Same thing here. I have 5 cameras outside and when checking a little while ago my recent history has disappeared. the last recordings in my library are on May 1 2017, first recording at 7:xx AM and last one at 11:xx PM.
I wonder whats going on?
Andrew
you should be able to get them on the main webpage still
Me too cant seem to see any of my videos shows last time was May 20th worked this am now all gone the number I found for them is 408-638-3750 I called they will put you on hold for ever I hope this is just a glicth as I paid the one year service plan at $125.00 I think I should get some dort of a refund
This is BS!!!!!
Vacrt2002 wrote:
So is it just the mobile app that's missing the history???
no both web and app
brunsdon23 wrote:you should be able to get them on the main webpage still
nope web and app hosed
Same issue here.
On the phone trying to reach them for past 20 min now!
JPC wrote:Yup same here.. Is this happening for Basic plan only? that will be sad if it is..
happening on the middle plan too (which I have)
trebor711 wrote:
I'll add my two cents. I'm experiencing the same issue both on my smartphone (Android) and iPad. Seems to be an issue with mobile devices. My problem just started this morning.
app AND web both experiencing problems
