Arlo Pro or Arlo Hd for the Vegas heat?
I ordered both Arlo Pro and Arlo Hd and not sure which one to keep. The problem is that Arlo Pro works in temperatures up to 114F and often time we exceed that here in Vegas. I wanted Arlo pro because it is the better model but I am worried that it might be damaged by the heat in the summer.
On the other hand, Arlo Hd can withstand temperature up to 122F which would be perfect, but is not the best of both.
I wouldn't worry about the heat side of things. The Pro stops working at about -4F which isn't your issue. Stay with the Pro.
The official answer from technical support was that the heat might or might not damage the camera and the battery. That is why I am still debating and would like to hear from someone who had them working in such conditions.
