Arlo Pro on a Pro2 base station?
Hello all
I have an Arlo Pro 2 system with 6 cameras on the base station. I have an opportunity to buy 2 Arlo Pros for cheap and wanted to know if they would work on my current pro 2 base station?
Anyone know if this is possible? I believe y base system can hold up to 15 cameras right?
You can connect the cameras to your current base, but there is a limit of 5 simultaneous streams. Of course if you run into issues you could get a second base.
