Arlo Pro on a 4G LTE hotspot
  • 3239 Views
azhoman
I want to use the system in vacant houses so I would like to be able to use a wireless hot spot for the internet connection.  How do I accomplish that?  The 4G LTE T-Mobile Hotspot does not have an ethernet connection.
Will not work without an ethernet port....
Maybe you should look at an Arlo Go which is cellular based or a hotspot with a port
Or use a WiFi extender connected to the hotspot. The base can be connected to the extender.
Scott2ya
Luminary
Luminary
You might need to shop around, but if you can't find a device that has an ethernet port as well, I would would just find a cheap wireless router that can hop on your hotspot
