  • 6 Replies
  • 4086 Views
  • 5 In Conversation
Rjsiegelin05
I'm trying to set up my Arlo Pro and when I go to the "new to arlo" link on the app or on my computer the options that it gives you to select from do not include the Arlo Pro just the following are options to install.
Arlo Q
Arlo Q Plus
Arlo Baby
Australian Nighthawk M1
6 REPLIES 6
That's because you need to add a base first. Unless you happen to be using a Nighthawk M1, choose Base first, although I don't see that in your list. You can then sync the cameras to the base by choosing the wirefree cameras.
kalena
The Arlo Pro does not show up in the setup, nor does the Base Station.
The camera won't show unless the base is working. Are you just setting the system up or has the system been in use? WHat are the LEDs on the base showing?
kalena
Thanks! I got it working
Shortledge
How did you get it to work? We’re having the same issue.
Shortledge,
After claiming the base station, simply tap add device and select "Arlo Wire-Free" and follow the on-screen instructions to sync cameras. Are you still experiencing an issue?
