Arlo Pro not recording all motions
  • 1 Reply
  • 1214 Views
Klin
I have my smart alerts set to give me notifications for People, Animal and All other motions. Arlo used to (back in August) record ALL (people, animal, vehicle, and all other motions) triggered activities. But now it only record the activities that I have selected (people, animal, and all other motions).
I want to be able to record vehicle triggered activities, but I don't want to receive notification. What can I do?
It's working as designed. Smart is post-processed by the servers and will discard videos that are determined to NOT be one of those selected. If you want all videos, enable local recordings in the base's settings for local recording. Depending on the base or hub you have, you can use the app to view them but you may have to safely eject the drive to view them on a computer if not using a VMB4540 or higher.
