Charged overnight, blinking blue light at start, no solid blue light after over 12 hours charging.
Forgot to turn on LED light to confirm full charge.
It only takes about 3 hrs for a full charge... unplug, and pull battery then replace...resync if needed ( tho you shouldnt ) check battery level in settings for that cam
( sometimes the blue led doesn't go out )
