Arlo Pro live feed
  • 1 Reply
  • 2616 Views
onmovingdanceco
I am looking to install a camera to link up to a tv in the lobby of a dance studio.   Installing wired cameras is not practical at the location. The cameras would provide year round viewing for parents.  I need two cameras for two different rooms.  First, can these cameras be used for live feed to a tv?  Can two cameras be used on the same tv?
Streak2
Master Master
The main problem you would have is that the Arlo Pro is not designed for continuous viewing.
To conserve battery power, the systems main focus is motion based recording.
If you require continuous live viewing you would at least have to run a power or POE cable to a suitable camera.
You could then look at the Arlo Q plus a CVR subscription to give you 24/7 viewing.
There are various ways to get the image to the TV screen but lets first see if you can do the above.
