Arlo Pro image Artifact top LH Cnr
New camera set up tonight and Visible using infrared noticing top LH of image has a slightly rounded white corner on still camera shots and all video for first nano second when played then disappears, probably there during day but not noticed yet, should I take it
back for a replacement ?
It's probably just a bit of interference. I don't think a new camera would change it. You're lucky to not have any other interference in your videos.
Thx Steve, It appears in all shots, same location, same size, everything is a static cropping, doesn't appear to be interference given consistency.
See zoomed image below for the white crop - appears something in the camera doesn't move out of the way of the lens at start up quickly enough.
Oh right. So possibly a lens / sensor alignment issue
