Arlo Pro iOS app says camera is offline but works via desktop in chrome
  • 7 Replies
  • 2335 Views
Chobie
When I open the iOS app it will briefly display the controls for one of my cameras before it tells me that the device appears offline.
If I use the web app via Chrome on my desktop then this issue doesn't appear and I can view live video or change the settings.
The camera in question still triggers on motion and records footage correctly, it just seems that the iOS app is reporting the status incorrectly.
My setup is 3x Arlo Pro and it only affects the 1 camera and on the phone app. I've tried removing the battery and removing it and adding it again but the issue persists.
Any ideas?
Chobie
I tried this but it didn't work.
The new app update seems to have fixed it though!
7 REPLIES 7
Are you using os 12.x  ?
Chobie
Yes, I am using iOS 12. But this issue persisted before the upgrade.
JessicaP
Hey @Chobie,
Have you tried to uninstall the app, restart your iPhone, and reinstall it again? Also, what iPhone are you using?
Chobie
I am using iPhone 6s Plus.
I tried the steps you mentioned and the problem still exists.
I did notice after reinstalling I didn’t need to enter my details again. Is it due to an iCloud backup or something?
JessicaP
Hm, try to log out and uninstall the app, restart your iPhone, and reinstall to see if you have to re-enter your details again. If you are still having problems that your camera is showing offline on your app, I would suggest contacting our Arlo Support Team so they will be able to assist you further.
pc2k17
Hero
Hero
Yes. Turn off and delete any cloud backups you may have before uninstalling and reinstalling. On android we can clear data and clear cache for the Arlo app, if you have something simliar on iphone try that first.
Chobie
