Not sure this mode is possible but I want it to look like this:
When Porch camera detects motion Porch will record -
When Porch camera detects motion Street camera will record -
When Backyard camera detects motion Backyard camera will record
Is that possible and if so how do I do that? Right now it feels like two separate modes and obvioulsy you can only run one mode at a time.
Make a custom mode....
A senses, A records
A senses, B records
C senses, C records
hint, you enter the first rule and save, then go back and edit the new mode to add additional
Thanks but when I do that the porch (or camera detecting motion for A&B in yoru scenerio) doesn't detect motion. It will when it is set as porch only. I think something may be wrong with that camera. Thanks anyway
The back camera worked just fine (C scenerio camera) but every time I have to Disarm the Arlo that first camera has to be re-synced. Def a problem.
dashmonkey,
What do you mean when you say the camera has to be resynced? What are you experiencing that requires this?
