Arlo Pro has reverted to grayscale
B&W means the light level is below the color threshold in the camera. Increase the ambient lighting and it will revert to color.
Post a screenshot which may help us. Yes, you may have to move the camera since it's outdoors and apparently during daytime but it also depends on where the camera is pointed.
Moving the camera is really not an option for me unfortunately.
Same area. Camera closest to porch shows color.
A new twist to this phenomenon. The camera is still showing grayscale, any time of day. However, I am now noting that the first few seconds of a recording is indeed in full color. So, it sees the color but for some reason reverts to grayscale. I am guessing this would seem to be more than just a threshold situation. And again, the other three cameras are all on the same lot subject to the same conditions.
I'm seeing this, too, on one camera. It's not clear to me exactly what's going on. Adjusting the brightness doesn't really help although it actually appears to be a brightness and/or contrast issue. A certain amount of color is visible in certain objects but the rest just seems washed out. I haven't tried removing the camera and resyncing it yet to see if that helps - have you?
