Arlo Pro false low battery indication. Changed batteries but did not fix.
  • 1 Reply
  • 873 Views
JimDel
I have 4 cameras that worked well and changed the batteries when indicated. I have one that now malfunctions and shows a lot battery even with new fresh batteries. I have checked the contacts inside and the order of the cells is correct. It will not connect to the network and will not function.
Contact support using the link at the bottom here.
