  • 6 Replies
  • 2173 Views
Station_10
Hello----I have 4 Arlo pro camera's using VMB4000. All 4 detects motion but only one does not record to my Library. I removed battery and re-inserted. Still doesn't record. How to resolve?
Anthony
Station_10
Problem resolved. Thanks for all the Arlo community members who came to my rescue!!
6 REPLIES 6
Dannybear
Try creating a custom mode that mimics the armed mode and see if that fixes it when you select the new mode.
Can you make a manual recording while livestreaming from the one that isn't saving to the the library?
Station_10
Thanks for the quick reply. How do you create a custom mode? Not sure where to begin.
Station_10
Hello Stephen-Please explain how to make a manual recording.
Dannybear
Regards @StephenB  question, while on main page showing cameras, select the play button to live view the camera and select the record button to record for a while, then check the library for the manual recording.
Regards the custom mode,
https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
Station_10
