Arlo Pro constant motion triggered in night/IR mode, tested by placing in a drawer, issue continues
  • 1 Reply
  • 1547 Views
Justcliff
I ordered a 3 pack through Costco and they were delivered 3 days ago.  Easy set up, and I thought all was working well until nightfall.  One camera was constantly triggered by motion and recording every two minutes.
I pulled the battery out and moved the camera to a  different location, I also changed the sensitivity settings for the audio and video.  This issue continued.
I then placed the camera in a drawer, completely dark, no noise, and it continues to trigger movement and record every two minutes.  I believe I have tried everything and was hoping for some additional advice.
Thanks in advance.
Use Settings and REMOVE DEVICE
pull batteries to reset camera, replace
Bring back the camera as new...
If problem continues, either take it back or contact Netgear Support for warranty
