Im wanting to install these cameras in my home..its exceptionally large 7500 sq ft. can i install more than one base for all of the cameras to work? is there an additional charge if you have more than one base. No way to run wiring at all so at the second base i assume i would need an extender of some type..thanks
No issue with multiple bases, just the total number of cameras.
As menttioned no limit to bases... Just be aware that while all the cameras used by your account will appear at the same time, they will be separately controlled by each base... As the bases respond each with their own arming/schedule/etc.
Base A has cams 1,2,3 and Base B has 4,5
Your would have to arm Base A and armed Base B for all cameras to be active...
