Arlo Pro cameras won’t sync but arlo do
Hi
I had an gen one arlo base station. There were three cameras synced. Two pros and one first gen. I have just replaced the base station with a pro and bought two more pro cameras. None of the pro cameras will sync I get a very fast orange blinking light on the camera
The gen one arlo camera syncs within seconds.
Can anyone help?
Can anyone help?
Update. I have reinstalled my gen one base and all cameras including the new pros that came with the pro base sync with that. So why won’t the new base sync with them?
Contact Support at the green banner below. Possibly the base unit was previously owned or is defective.
Brian
It might be worth removing the new base from Settings, My Devices. Press the reset button until the LADs flash amber and let it reboot until the power and Internet LEDs are green. Use Add Device on the Devices tab to claim the base again and verify that the firmware is up to date. Try syncing. Be sure to only briefly press the base sync button - don't hold it.
Thanks Both, It arrived in brand new pachaging and didn't look previously owned.
I will reset etc. Will have to be next weekend as dont have time in the week. At the moment all the cameras are connected to the gen one base and working.
Thanks again.
Josh
