Re: ADOBE FLASH IS THE CULPRIT ON CHROME
Highlighted
It started yesterday. I cannot receive live streaming images from my 4 cameras. If motion detected they record fine. I use live 90% of time, so. I have reset base station to factory. reset router, and computer. Cannot see live from my phone either. I'm going to have to install a wired system. This has happened before, wish I could remember fix.
Model: VMC4030| Arlo Pro Wire-Free Camera
Highlighted
Turns out I wasn't up to date on Chrome when I replied.  The latest Chrome defaults to disabling Flash for security reasons.
You can fix this by changing Chrome's settings.  Go to Privacy and Security, Content Settings, Flash.  Either enable Flash or add arlo.netgear.com in the Allow section at the bottom.  Then type in "chrome://flags" (no quotes) and search for flash. Look for the section labelled "Run all Flash content when Flash setting is set to "allow"" and enable the setting.  That will prompt you to restart Chrome.  After the restart, live view should be working.
All Replies
Highlighted
Luminary
Luminary
Ours won't stream either..just a 'please wait' and then it goes back to non-live screenshot.
Highlighted
Same issue; noticed it this morning.
I restarted base station and removed one camera and then added it back but this did not resolve the issue.
Camera positioning works to give a live view but I want to change my brightness.
Base station VMB4000r3 - firmware 1.8.10.1_13433
Camera Firmware    1.092.0.4_13099
Highlighted
It appears to be an issue with Chrome and Adobe Flash; the blocked icon appears next to bookmark icon.  I have settings to allow flash and if I select the blocked icon to allow it works for the first camera I try but not others.
I updated Chrome and Adobe but same results.
I tried it using Epic Privacy browser and have not had any issues.
Highlighted
Adobe flash is being phased out.  If your on chrome as your platform your live camera feeds will not work.
Switch to Microsoft Edge and update flash and you should be all good to go
Highlighted
I can use live view on Chrome with no problem.  BTW, Edge is not a supported browser although it does work.
Highlighted
Luminary
Luminary
PLEASE HELP ASAP.  ok so what browser is SAFE and can run this thing because I have heard so much bad about Mozilla, Edge (because of Flash), and now Chrome(even though it was recommmended ). We dont do the mobile apps and use only our HP desktop. My Flash is enabled on chrome, but icon says it isnt..updated chrome, on current flash...still cannot get LIVE viewing back for 2 days.. Is there a drawback to restarting base? will we have to resync all cameras afterwards? We are experiencing a nieghbor problem and must have  live to catch the woman.
Highlighted
Highlighted
Thanks!  Making the change in chrome://flags resolved the Chrome issue for me.
Highlighted
Luminary
Luminary
Thank You!  That solved our problem with Chrome and live viewing. In the meantime, Edge worked for live. Our microphone has never worked since installing this system and we've given up on ever using that feature much to our dimay.We are simple ppl who are not computer savvy and geeez do we wish we knew even a third of what you do.
And our model VMB4000 wasn't on the list..
Thanks again Superuser!
Highlighted
That worked!  Thank you
Highlighted
Thanks jguerdat, this fixed my "no live feed".  Still waiting for Arlo support to get back to me after requesting support 3 days ago.
Highlighted
chrome://flags
fixed the problem with streaming the camera via Chrome - it just started on Thursday 7/28/17
Model: arlo.netgear.com | Web Site/App
Highlighted
THANK YOU!! This fixed it!
Trying to work thru this issue.  Enabled Flash, Added Arlo website, Typed "chrome://flags" no (")- but it says nothing found.  Am I typing this in the right place??  Still not working.  Any responce will be appreciated.
Highlighted
Are you typing chrome://flags in the URL bar?
Highlighted
No, it was in the settings panel where i enabled the flash. Also tried the url bar too.
Highlighted
Be sure to follow the steps closely in my post. Enabling Flash is done in Chrome's Settings but the flag is set by typing chrome://flags in the URL bar, two very different things.
Highlighted
Tired again. It works. Thank you very much.
Highlighted
Highlighted
Thank you! This worked for me although IDK why it suddenly stopped working to begin with.
Model: VMC3040 | Arlo-Q HD with Audio
Highlighted
This worked!  Thank you,
Highlighted
Thank you so much. That was exatly what I needed. My Arlo is up and running again.
Highlighted
I had the same problem, in the beginning I was using the Chrome Browser, I logged out and logged back in using the Microsoft Edge Browser and everything worked fine. Also, if you try and use a mobile device like a phone, tablet, and etc. and if you can do live stream through your cameras, this is when you know the Cameras and the Base IS NOT the issue.
If the methods above does not work:
(1)  try turning off your Arlo cameras
(2) turn off the Arlo Base station
(3) remove the batteries from all Arlo cameras for about 10 minutes or so
(4) reinsert the batteries back in the cameras
(5) turn on the Arlo Base Station, pause for 5 minutes so the Arlo Base Station can connect to all the Arlo Cameras
(6) turn on all the Arlo Cameras
Model: VMC3030 | Arlo Wire-Free Camera
Highlighted
The real issue is that browser's are starting to not support Flash. The latest update to Chrome turns Flash off and you have to manually turn it back on. That's what my directions above do. It's only a matter of time before other browser's block Flash, too.
