I have 5 Arlo Pro VMC4030 cameras, and onet went offline a few weeks ago. When I reseat the battery, I get a solid blue light for two seconds, and that's it. Then when I press the sync button, there are no lights whatsoever. After reading another support discussion with similar symptoms, I've removed that specific camera device from the Arlo settings Device List in hopes to re-sync it --but the issue seems to be camera device specific. I've tried swapping the battery with a known-working battery from one of the other cameras --so it's definitely not a battery issue. I've checked the battery contact terminals, compared it to known-working cameras --and the contacts are intact and springy. The only other sign of life I can get from the camera is while the battery is inserted, I attach the AC power plug, then get rapid blinking blue lights for two seconds.
Any help would be greatly appreciated! Thanks.
