Don
Don
Only the app was updated recently. That does not affect camera batteries.
What base firmware do you have?
What camera firmware do you have?
How many minutes a day are you recording and/or live viewing on each camera?
Have you tried restarting the Arlo base?
There was a battery drain issue over the summer, but that was fixed with a firmware update to the base and cameras.
Recording minutes and live viewing time has not changed recently and it is not substantial. Yes, the base was restarted yesterday.
Thanks for insights!!!
Your firmware versions are current. It could be some type of new interference that's causing the cameras to lose conection to the base and constantly reconnect, which would drain the batteries.
Couple things to try, bring one camera right close to the base and leave it there for a bit and see if battery drain gets better or you could try swapping camera locations temporarily and see if things change.
Don
