I would like to use Arlo cameras in a location that does not have a typical internet router. Internet access is obtained solely with a Verizon Mi-Fi device. There is not a RJ-45 network port on the Mi-Fi device therefore I do not have any way to connect the Arlo base tation to the internet. I am looking for ideas.
Use a WiFi extender that has an Ethernet port. The extender connects to your WiFi and the base connects to the extender via the cable.
hi, i'm from Hong Kong and shared the same issue with you.
i am now using a router with sim card plug in (tp link archer mr200)
