Arlo Pro arms on its own
Try using a browser instead of the app - I find it works better. You can use a mobile browser if needed by setting the browser to use the desktop version of the site.
I can try this. Are you thinking that the way that I disarm the system (app vs. browser) is the reason that it will re-arm on it's own some time later?
It may be possible esp if your running new iOS 11 ( seen strange things lately )...
either way testing on a computer will eliminate the possibly and allow a better answer.
Netgear, you have got to fix this. This is so annoying. My kids play in the backyard all the time. I have to disable the cameras constantly as is -- but now I have to do it every 15 minutes because the stupid thing is arming itself. This is a major issue and unacceptable. I am about to permenantly put my cameras in a drawer.
Issue still present here. Rebooted base station several times, even disconnected from IFTTT, still re-arms itself after being disarmed for several minutes.
To be fair, I haven't had the time to contact support about this, so I've just kind of accepted it for now. Anyone actually talked to support about this issue, or are we all just here venting in hopes someone will see this? 🙂
