Arlo Pro reads 0% charged while plugged into working Arlo recharger and cords. I actually put a Arlo batter in that another camera said had a 75% charge and it still read 0% charged.
Answer: Remove the camera from the Arlo Hub using controll center or App. Then follow instrtions to reconnect the cammera to the Arlo hub.
Or sometimes a simple reboot of the base fixes it ( power off then on )
