Arlo Pro VMC4030 not recording or adhering to routines
Arlo Pro VMC4030: 4 cameras
1. Routines do not work. For example, activate AWAY, which should turn on every camera, but nothing changes. That shortcut worked when it was first introduced, but not now.
2. Cameras are not recording. Live feed shows a great picture, but not recording motion.
I have tried all recommendations- removed the batteries, reset the base station, removed and added cameras back to base station, checked all settings, done a motion check (yellow light flashes)…..
Cameras are 7.5 years old and worked beautifully up until about 2 months ago.
You should still be on the subscription free plan but go into your settings and make sure that all camera are active in the plan.
Can you watch your cameras throughout the day and see if the behavior is different.
