Arlo Pro Plugged In With Battery
I'm just trying to find out if the battery would be damaged if left plugged in indefinately. The camera was purchased primarily to comunicate with mute parent in assisted living facility; so security is not the issue here. Being able to talk and view parent at the same time through the camera would probably drain battery too fast; and there will be 3 of us using it at different times; so I'm wanting to keep it plugged in so it is care-free for parent. Please advise. Than you much; we may have to purchase charging station with extra batteries; if this causes damage to the battery.
No problem. The camera limits the actual charge level to 80%, the recommended level for best Li-ion batteries. The indicator shows 100% but that's 100% of that 80%.
