  • 2 Replies
  • 835 Views
garkw
1) How long in general would the original battery last on the Arlo Pro camera? Two of my cameras are no longer being charged with the original batteries and charging plug. The other two still work. 2) Am I suppose to replace them?? I already tried re-plugging, cleaning out dust or etc.
All depends on usage... but like most li-ion packs sure be good for a couple hundred recharge cycles.
If you drain them to low, the charger has an issue starting a charge... follow this info;
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
And, yes, they can be replaced...see accessories page.
If you're still in your warranty period, open a case with support:
