Arlo Pro - Need Help Syncing
  • 1 Reply
  • 1439 Views
JohnS64
I just got my Arlo Pro. I cannot get one camera to sync. Just get the amber light. Any ideas?
Main thing is to make sure you doing a quick press on the base sync button ( NOT hold )...
If it fails, pull battery, wait about 5 mins, reinstall  and  then press base sync then camera sync
