Arlo Pro - Is it a good product for what I'm after
  • 1 Reply
  • 1678 Views
BrendEH
Hi All,
I am looking for a portable option for capturing High Def visual footage that is a standalone system. Having its own power supply, internal storage and around a fortnights battery when on motion activation.
cheers
No, the Pro prob will not work as it really isn't stand alone....it requires a base unit which must be powered and located at about 200 feet or less away from the camera ( max range is 300 feet listed but in real world Ive gotten 175ft max )
The only camera that is really stand alone with its own power would be a Go camera... it is cellular base using LTE for vids.. should get about a month usage+ ( depends on how much recording )
But it also records to the cloud and an internal mem card
see; https://www.arlo.com/en-us/products/arlo-go/default.aspx
