Arlo Pro Intermittent Yellow With New Battery
  • 4 Replies
  • 2291 Views
Jim3000
Flashing yellow. Replaced with new battery. Still flashing intermittent yellow. Replaced with new battery charged in New arlo pro. Still flashing yellow. Dead arlo?
Sounds like it. Swap at the store or open a case with support here:
JPC
Prodigy
Prodigy
Could be updating your cams.. Did you let it sit for awhile and see if it stops? I have come across with Older batch of Arlos sometimes takes a bit of time to update to the latest firmware....  Try plugging it in and see if it continue doing this and if it does then time to call support or return to where you bought it if still under warranty..
Updates should flash an alternating blue and amber, not just amber. A slow flashing amber means low/dead battery.
JPC
Prodigy
Prodigy
True, supposedly it should look like that.. I used to believe that too.. Not anymore eversince Arlo released all kinds of updates.. I'm experiencing something that's way different now than what it should..
