Arlo Pro Charging with a Powerbank
Hi,
does anyone know if an Arlo Pro CAM can be charged with a Powerbank? If supportted, what would be the charging capacety needed for a Powerbank? Maybe we can also recommend one in case someone experanced it to work.
Thx
Markus
More than likely NOT..... the PRO battery pack is 7.2v and goes to 8.4v when charged.... this is why it needs a Qulacom dual voltage charger that supplies 5 & 9V . ( needs 9v to charge battery pack )
Most power packs I know of supply the normal usb standard of 5v only so it will not charge.
